A parameter is an event property that can be used to trigger and control an event's instruments, logic markers, and automateable properties, and whose value can be set by game code. This chapter describes the properties, settings, and behaviors of each type of parameter in detail.
For information about adding parameters to events and possible uses of parameters in games, please see the parameters section of the authoring events chapter and the parameters chapter.
A preset parameter has settings that can be changed in the edit parameter dialog.
The following settings are common to most preset parameters.
Studio::System::getParameterByName and Studio::System::setParameterByName in the FMOD API Manual, and for information on getting and setting the values of local parameter instances, see Studio::EventInstance::getParameterByName and Studio::EventInstance::setParameterByName.Other properties that appear in the edit parameter dialog are specific to certain types of parameter.
Certain additional parameter properties can be viewed in a parameter's deck.
The parameter deck allows you to set a parameter's current value, as well as the preset parameter's velocity and seek speed settings.
When a parameter is subject to both seek speed and velocity, setting the parameter to a new value causes it to ramp to that value at the rate specified by its seek speed, then to resume moving at the rate specified by its velocity.
Every property and setting of a preset parameter is shared between all parameters based on that preset parameter.
Unlike all other parameter types, timelines do not reference preset parameters, and cannot be created or changed with the edit parameter dialog. Timelines can contain logic markers, but cannot be used for the parameter trigger conditions of instruments or logic markers.
An event can contain no more than one timeline parameter. Timelines cannot be given names.
A timeline's minimum value is always 0. The maximum value of a timeline is based on the rightmost logic marker or instrument on that parameter. The initial value of a timeline is always 0.
Timeline parameters are always local in scope, and the value of a timeline cannot be modulated or automated.
The value of a timeline automatically advances when the event instance containing that parameter is playing, unless its current value reaches a sustain point. The rate at which a timeline advances is scaled by the event's pitch property, found in the event's macros drawer.
Your game's code can get and set the value of a timeline with Studio::EventInstance::getTimelinePosition and Studio::EventInstance::setTimelinePosition.
If a non-persistent event instance's timeline reaches its maximum value and no other content is playing in that event instance, the instance automatically enters the stopped play state.
User parameters are parameters that can be customized to represent any variable in your game. Unlike built-in parameters and timeline parameters, they do not update automatically, and must be set by your game's code or adjusted by automation or modulators.
The following settings are common to preset user parameters, and can be changed in the edit parameter dialog.
Continuous user parameters use floating point (decimal) numbers.
Each continuous parameter has a minimum and a maximum value that defines its range, and can be set to any floating point value within that range.
The initial value of a continuous parameter may be any floating point number within its range.
Labeled user parameters use strings (labels) instead of numerical values. The labels of a labeled parameter can be viewed and edited in the edit parameter dialog.
The range of a labeled parameter is automatically derived from its labels, and is always 0 to n, where n is the index of its last label. The value associated with each label can be viewed in the edit parameter dialog.
The initial value of a labeled parameter may be any label within its range.
Discrete user parameters use integer (whole) numbers.
Each discrete parameter has a minimum and maximum value that defines its range, and can be set to any integer value within that range.
The initial value of a labeled parameter may be any integer number within its range.
Built-in parameters are parameters whose values automatically update based on the 3D attributes of the event instance and listener in your game engine.
When auditioning in FMOD Studio, you can alter the auditioning event instance's 3D attributes by moving the event instance in the 3D preview tool, or by changing the values of its built-in parameters in the editor.
Built-in parameters are always local in scope.
For information about adding parameters to events, please see the parameters section of the authoring events chapter.
For the purposes of setting event instance positions and listener positions in your game's code, FMOD Studio uses the 3D Cartesian coordinate system, with the x and z axes used to describe the horizontal plane, and the x and y axes used to describe the vertical plane.
For more information about how 3D attributes are set in your game's code, see Studio::EventInstance::set3DAttributes and Studio::System::setListenerAttributes in the FMOD API User Manual.
Below is the legend for all diagrams used in this section.
The distance parameter type represents the distance between the listener and the event instance. It uses the same units of distance as the game engine.
Each distance parameter has a minimum and maximum value, and is automatically set to the distance between the event instance and the nearest listener. This range can be customized. At value 0 the event instance is closest to the listener. A higher value represents greater distance.
When auditioning in the event editor window, moving the event instance in the 3D preview towards or away from the listener changes the value of the event's distance parameter.
Note that the game's distance factor, set by the distancefactor property in System::set3DSettings, does not have any effect on the distance calculated for a distance parameter. The calculated distance is based on the units used when setting the position of the listener and the event instance.
The direction parameter type is the angle between the direction the listener is facing and the direction from the listener to the event instance, in degrees.
A direction parameter has a minimum value of -180 and maximum value of 180. Each is automatically set to the angle between the direction the listener is facing and the direction from the listener to the event instance on the horizontal plane. 0° is positioned directly in front of the listener, -180° or 180° is positioned directly behind, -90° is positioned to the left of the listener, and 90° is positioned to the right of the listener. Direction parameters only take into account the listener's horizontal (xz) plane.
Direction parameters differ from event cone angle parameters in that direction parameters are based on the direction from the listener to the event instance, while event cone angle parameters are based on the direction from the event instance to the listener.
When auditioning in the event editor window, moving the event instance in the 3D preview around the listener changes the value of the direction parameter.
The elevation parameter type is the angle between the direction the listener is facing and the direction from the listener to the event instance on the vertical (xy) plane, in degrees.
Each elevation parameter has a minimum value of -90 and maximum value of 90, and is automatically set to the angle between the plane formed by the listener's forward and left vectors (noted as the "listener's horizontal plane") and the vector between the listener and the event instance. At 0° is when the listener's horizontal plane matches the vector between the listener and the event instance. At 90° is when the listener's horizontal plane is directly below the vector between the listener and the event instance (ie. the event instance is above the listener), and at -90° is when the listener's horizontal plane is directly above the listener (ie. the event instance is below the listener). Elevation does not take into consideration whether the listener is looking at the event instance.
An elevation parameter can be used in situations where it is important that event instances sound different if above or below the listener, such as when a player is in a World War I-era biplane.
When auditioning in the event editor window, moving the event instance in the 3D preview above or below the listener changes the value of the elevation parameter. You can do this by holding onto the Ctrl key and dragging the event instance.
The event cone angle parameter type is the angle between the direction the event instance is facing and the direction from it to the listener, in degrees.
An event cone angle parameter has a minimum value of 0 and maximum value of 180. Each is automatically set to the absolute value of the angle between the direction the event instance is facing and the direction from the event instance to the listener on the horizontal plane. At 0°, the event instance faces towards the listener and at 180° the event instance faces away from the listener. Event cone angle only takes into account the horizontal plane (xz).
Event cone angle parameters differ from direction parameters in that direction parameters are based on the direction from the listener to the event instance, while event cone angle parameters are based on the direction from the event instance to the listener.
Some events represent objects that emit sound in a non-spherical manner, such as televisions or megaphones, and this parameter type can be used to define how such events behave. It is often used to define the size of the emission cone for an event.
When auditioning in the event editor window, rotating the event instance in the 3D preview changes the value of the event cone angle parameter.
The event orientation parameter type is the angle between the direction the listener is facing and the direction the event instance is facing, in degrees.
An event orientation parameter has a minimum value of -180 and maximum value of 180. Each is automatically set to the angle between the direction the listener is facing and the direction the event instance is facing, as measured on the horizontal plane. If both the listener and instance are facing the same direction, the angle is 0°. As the listener and the event instance turn to face opposite directions, the angle will increase toward a maximum of 180°. The event orientation parameter only takes into account orientation on the horizontal plane (xz).
The event orientation parameter is useful when an event represents a sound that surrounds the listener instead of coming from a single point source, such as a wind ambience that sounds different depending on which way the listener faces relative to the wind direction.
When auditioning in the event editor window, rotating the event instance in the 3D preview changes the value of the event orientation parameter. Rotating the listener in the sandbox window will also change the value of the event orientation parameter.
The speed parameter type represents the speed of the event instance relative to the listener. It is measured in units of distance per second, and uses the same units of distance as the game engine.
Each speed parameter has a minimum value of 0 and a maximum value, and is automatically set to the speed at which the event instance is moving relative to the listener. When the event instance is moving at the same velocity and in the same direction as the listener, the value of the speed parameter is zero. Higher values represent greater differences in velocity. For example, if the listener is moving at a rate of 1 unit/second and the event instance is moving in the opposite direction at a rate of 10 units/second, the value of the speed parameter is 11.
The range of a speed parameter can be customized. The maximum value of a speed parameter must be greater than its minimum value, and its minimum value cannot be less than zero.
The 3D preview tool and sandbox do not alter the value of the speed parameter when auditioning events.
