Unity Integration 2.02
Enter text here to filter the tree view. Any Events that match, or are underneath a folder that matches will be shown.
This shows all the FMOD Studio objects available, split into Events, Snapshots, Banks and Global Parameters. Items selected here can be dragged onto the scene window to create Game Objects, or dragged onto some parts of the Inspector window.
Various properties of the selected object are shown here. The button will copy the complete Path to the clipboard for easy access when writing scripts. The Names and IDs of Global Parameters can be copied in the same way.
Play, and Stop buttons allow you to preview an Event inside Unity. The Show In Studio button will focus the selected Event inside FMOD Studio if it is running.
This lists all the parameters on the selected Event, and allows the parameters to be changed during preview.
When a 3D Event is being played the arrow can be moved around to simulate the Events position relative to the listener which is placed at the center.
This shows the metering on the projects Master Bus.
