Unity Integration 2.02
This section describes the major features introduced in the 2.02 release. See the Detailed Revision History for information regarding each patch release.
General runtime features and improvements, including any API changes relevant to scripting, are documented in the API what's new page.
The [EventRef] attribute has been replaced with the new EventReference type. We made this change so we could use the most efficient way of looking up an event at runtime, while keeping the editor UI usable. See the basic scripting example for examples of EventReference usage.
The EventReferenceDrawer class is a PropertyDrawer for EventReference properties that provides a UI similar to the old [EventRef] UI. See the scripting API reference for an example.
To assist with migration to the new system, you can use the Event Reference Updater tool. This will scan all the scenes, prefabs and ScriptableObjects in your project for [EventRef] fields and guide you through the process of migrating them to EventReference fields.
The [EventRef] attribute has been marked as obsolete so that any usage of it will generate compiler warnings, making it easy to see where it is used in your project.
The Event Browser now shows global parameters in the correct folder hierarchy, matching the FMOD Studio preset browser.
The minimum version of Unity supported is now 2019.4 to reflect the Unity LTS cycle.
This section describes the major changes that occurred in 2.01.xx leading up to the release of 2.02.
Added support for PS5, Game Core and iOS simulator.
We have added a new setup wizard to help you integrate FMOD into your Unity project. It will appear when FMOD for Unity is first installed, and can also be accessed via the FMOD/Setup Wizard menu command.
The setup wizard guides you through these basic integration tasks:
When updating to a new version of FMOD for Unity, the system assists you with:
The Settings inspector has received a visual refresh and a significant overhaul of how platform settings are supported.
The new and improved settings include:
Parameters and volume can now be automated on the Unity Timeline.
We have added a menu command to easily integrate with Visual Scripting, using Bolt Visual Scripting in older Unity versions and Unity Visual Scripting in newer Unity versions.
