Scripting API Reference | Project.Entity
26. Scripting API Reference | Project.Entity
A studio.project.Entity provides information about the type of a ManagedObject.
The entity for a given ManagedObject can be retrieved using ManagedObject.entity. This provides the string representation for an entity, which can then be looked up in the project.model.
Properties:
  • entity.isAbstract A constant boolean value that is set to true if an object is the base class of another entity type.
  • entity.isGlobal A constant boolean value that is set to true if an entity exists globally, rather than on a per project basis.
  • entity.isSingleton A constant boolean value that is set to true if only a single ManagedObject instance of the entity can exist at any given time.
  • entity.properties Returns an array of property description objects containing named properties that represent each ManagedObject property available for this entity.
  • entity.superentities An array of strings representing the entity type inherited by this entity.
Methods:
Objects:
entity.isAbstract
Abstract entities cannot be instantiated with project.create.
entity.isGlobal
entity.isSingleton
entity.properties
See Also: Property Description Object
entity.superEntities
entity.document
Returns a string describing the entity, including its properties and relationships.
entity.document()
entity.findInstances
Returns an array of ManagedObject instances of a given entity type.
entity.findInstances(
    [options]
You can optionally pass an options object { searchContext, includeDerivedTypes }. Passing a managed object for the searchContext field confines the search to children of that object. Passing true for the includeDerivedTypes field will allow derived types of the given entity to be returned.
For example:
// find all SingleSounds within the project
studio.project.model.SingleSound.findInstances();
// find all SingleSounds within the currently selected event
studio.project.model.SingleSound.findInstances({ searchContext: studio.window.browserCurrent() });
// find all GroupTracks, ReturnTracks and MasterTracks within the currently selected event
studio.project.model.AudioTrack.findInstances({ searchContext: studio.window.browserCurrent(), includeDerivedTypes: true });
entity.singletonInstance
Returns the singleton ManagedObject instance of a particular entity type.
entity.singletonInstance()
An error will be thrown if the entity is not a singleton type.
Relationship Description Object
An unnamed data object describing the relationship between two entities.
    cardinality: [string],
    destinationType: [string],
    isRequired: [bool]
cardinality
Description of relationship, e.g. one-to-many, many-to-one.
destinationType
Entity type the relationship targets.
isRequired
Indicates whether this relationship is required.
An unnamed data object containing the data type and default value of a property.
    dataType: [string],
    defaultValue: [variant]
dataType
The type of data the property represents.
defaultValue
The default value of the property.
This is the object type returned from entity.Properties.
entity.relationships
Returns an array of relationship description objects, containing named relationships that represents each ManagedObject relationship available for this entity.
See Also: Relationship Description Object
