Scripting API Reference | Project.ManagedObject
26. Scripting API Reference | Project.ManagedObject
Project level data in Studio is represented as a graph of managed objects. A managed object is comprised of:
Beyond the generic interface presented for each ManagedObject, a number of extension functions are available for ManagedObjects of a particular project.Entity type.
The root managed object of a project can be retrieved using studio.project.workspace. Objects within a project of a particular project.Entity can be retrieved using Entity.findInstances.
ManagedObject
Properties:
Methods:
ManagedPropertyMap
Properties:
Methods:
ManagedProperty
Properties:
Methods:
ManagedRelationshipMap
Properties:
Methods:
ManagedRelationship
Properties:
Methods:
ManagedObject.entity
A string representing the object's project.Entity type.
Lookup project.model to inspect details about the entity. Immutable.
ManagedObject.id
The object's unique ID.
Immutable.
ManagedObject.isValid
Returns whether an object is in a valid state.
An object may become invalid if it is deleted or if it has a null value for one or more of its required entity.relationships.
Immutable.
ManagedObject.properties
Provides access to an object's properties.
Returns a ManagedPropertyMap.
Immutable.
ManagedObject.%property_name%
Provides access to a ManagedObject property's value.
Setting the property (with the = operator) will set the property value.
ManagedObject.%relationship_name%
Provides access to a ManagedObject relationship's destinations.
Getting a ToOne relationship will return the single destination object (or null if it is unassigned). Getting a ToMany relationship returns an array of destinations (or an empty array if it has no destinations). Setting a ToOne relationship (with the = operator) will set or replace the current destinations. ToMany relationships cannot be modified with the = operator.
ManagedObject.relationships
Provides access to an object's relationships.
Returns a ManagedRelationshipMap.
Immutable.
ManagedObject.document
Returns a string describing this ManagedObject's entity type.
ManagedObject.document()
As an example, calling studio.project.workspace.mixer.masterBus.volume = 2, would walk through the Workspace's relationship to the global Mixer, then the Mixer's relationship to the MasterBus, and finally sets the volume property on the MasterBus to 2 dB.
See Also: project.Entity
ManagedObject.dump
Logs all members.
ManagedObject.dump()
Use this function to see what functions and properties are available on any ManagedObject. This is particularly useful for finding undocumented functionality.
ManagedObject.isOfExactType
Returns true if the object type matches the provided entity name.
ManagedObject.isOfExactType(
    entityName
entityName
The name of the project.Entity type to compare against.
This does not include derived types.
ManagedObject.isOfType
Returns true if the object has an entity that matches the entity name, or is of a derived type.
ManagedObject.isOfType(
    entityName
entityName
ManagedPropertyMap.parent
The owning ManagedObject of the property map.
Immutable.
ManagedPropertyMap.%property_name%
Returns a ManagedProperty for the given property name.
Immutable.
ManagedPropertyMap.dump
Logs all members.
ManagedPropertyMap.dump()
Use this function to see what functions and properties are available on any managed property map. This is particularly useful for finding undocumented functionality.
ManagedProperty.dataType
The type of data stored by this managed property's value.
Immutable.
ManagedProperty.defaultValue
The default value that the ManagedProperty was initialized with.
Immutable.
ManagedProperty.name
The name of the property.
Immutable.
ManagedProperty.parent
The owning ManagedObject of the property.
Immutable.
ManagedProperty.dump
Logs all members.
ManagedProperty.dump()
Use this function to see what functions and properties are available on any property. This is particularly useful for finding undocumented functionality.
ManagedProperty.setValue
Sets the value stored by the property.
ManagedProperty.setValue(
    value
value
Value to set managed property to.
Returns true if the operation succeeds, or false otherwise.
ManagedProperty.value
The value stored by the property.
Immutable.
ManagedRelationshipMap.parent
The owning ManagedObject of the relationship map.
Immutable.
ManagedRelationshipMap.%relationship_name%
Returns a ManagedRelationship for the given relationship name.
Immutable.
ManagedRelationshipMap.dump
Logs all members.
ManagedRelationshipMap.dump()
Use this function to see what functions and properties are available on any managed relationship map. This is particularly useful for finding undocumented functionality.
ManagedRelationship.cardinality
A string representing the object's cardinality.
Either ToOne or ToMany.
Immutable.
ManagedRelationship.destinations
An array of ManagedObject destinations.
Immutable.
ManagedRelationship.name
The name of the relationship.
Immutable.
ManagedRelationship.isOrdered
A constant boolean value that is set to true if the relationship is ordered.
ManagedRelationship.parent
The owning ManagedObject of the relationship.
Immutable.
ManagedRelationship.add
Appends a new destination to a relationship.
ManagedRelationship.add(
    managedObject
managedObject
ManagedObject to add to relationship.
Replaces the current destination for a ToOne relationship. Returns true if the operation succeeds, or false otherwise.
ManagedRelationship.dump
Logs all members.
ManagedRelationship.dump()
Use this function to see what functions and properties are available on any managed relationship. This is particularly useful for finding undocumented functionality.
ManagedRelationship.insert
Inserts a new destination to a relationship at a given index.
ManagedRelationship.insert(
    index,
    managedObject
index
Index to insert at. Must be in range [0, destinations.length].
managedObject
The ManagedObject to add to the relationship.
ManagedRelationship.remove
Removes a destination from a relationship.
ManagedRelationship.remove(
    managedObject
managedObject
ManagedObject to remove from relationship.
