Scripting API Reference | Project.Model.MixerStrip
26. Scripting API Reference | Project.Model.MixerStrip
model.EventMixerGroup
An audio track within a model.Event.
model.EventMixerMaster
The master track of an model.Event.
model.EventMixerReturn
A return track that can receive signals from within the event.
See Also: Sends and Return Buses, Return
model.MixerBus
The base class for routable buses.
model.MixerGroup
A model.MixerBus that accepts the outputs of other mixer buses as inputs.
See Also: Group Buses and Routing
model.MixerInput
A model.MixerBus that allows output from a model.Event to enter the project-level mixer.
Nested events, snapshots and profiler sessions cannot output to a mixer input.
See Also: Mixer Strip
model.MixerMaster
The final output bus in the mixer.
See Also: model.MixerStrip, Master Bus
model.MixerPort
An output to an external audio port.
See Also: Port Buses
model.MixerReturn
A return bus that can receive a signal from a model.MixerSend.
model.MixerStrip
The base class for elements represented as a strip.
model.MixerVCA
A model.MixerStrip that scales the volume of any other mixer strips assigned to it.
See Also: VCAs
MixerBus.getInputFormat
Retrieves the input format of the bus.
MixerBus.getInputFormat()
Returns the effective input format for a model.MixerBus object as an enumeration.
MixerBus.getOutputFormat
Retrieves the output format of the bus.
MixerBus.getOutputFormat()
Returns the effective output format for a model.MixerBus object as an enumeration.
MixerStrip.getPath
Retrieves the mixer strip's unique path identifier.
MixerStrip.getPath()
Returns the model.MixerStrip's path as a string.
