Scripting API Reference | Project.Model.Parameter
26. Scripting API Reference | Project.Model.Parameter
model.ActionSheet
A sheet for an model.Event that plays through a playlist of instruments.
See Also: Action Sheet
model.GameParameter
A built-in parameter or user parameter of a model.Event, whose input value is specified by the game.
See Also: Built-in parameters, User parameters
model.Parameter
The base class for a parameter sheet upon which instruments can be placed, within an model.Event.
See Also: Parameters Reference
model.ParameterPreset
An object representing a parameter in your project.
See Also: Parameter
model.ParameterProxy
An object containing a reference to a model.ParameterPreset.
model.Timeline
A parameter sheet of a model.Event that automatically increases its value over time.
See Also: Timeline
GameParameter.getCursorPosition
Retrieves the parameter's cursor position.
GameParameter.getCursorPosition()
Returns the cursor position of the global user parameter as a number. Returns undefined if the scope of the game parameter is not global.
var globalParameterPreset = studio.project.lookup("parameter:/game_state/time_of_day"); // return a ParameterPreset object
var timeOfDay = globalParameterPreset.parameter.getCursorPosition();
GameParameter.setCursorPosition
Sets the cursor position of the global, user, or built-in parameter to a number.
GameParameter.setCursorPosition(
    position
position
The numerical position to set the parameter's cursor to.
globalParameterPreset.parameter.setCursorPosition(1300);
See Also: Game Parameter
Parameter.getPlayheadPosition
Retrieves the playback position of a parameter, within the context of the associated model.Event.
See Also: Parameter
ParameterPreset.getPath
Retrieves the project's unique path identifier for the parameter.
ParameterPreset.getPath()
Returns the parameter's path in your project as a string.
See Also: Parameter
ParameterProxy.getCursorPosition
ParameterProxy.getCursorPosition()
Returns the cursor position as a number, within the context of the associated event.
This is only meaningful when dealing with global parameters, since local parameters do not have meaningful cursor positions outside of specific event instances.
The equivalent of calling parameterProxy.event.getCursorPosition(parameterProxy.preset).
ParameterProxy.setCursorPosition
Sets the cursor position of the parameter to a number.
ParameterProxy.setCursorPosition(
    position
position
The numerical position to set the parameter proxy's cursor to.
Sets the parameter's cursor position to a number, within the context of the associated event.
The equivalent of calling parameterProxy.event.setCursorPosition(parameterProxy.preset, position).
Timeline.getCursorPosition()
Retrieves the timeline's cursor position.
The equivalent of calling timeline.event.getCursorPosition(timeline).
Timeline.setCursorPosition
Sets the cursor position of the timeline to a number.
Timeline.setCursorPosition(
    position
position
The numerical position to set the timeline to.
Sets the cursor position to a number, within the context of the associated event.
The equivalent of calling timeline.event.setCursorPosition(timeline, position).
See Also: Timeline
