Scripting API Reference | Project.Model.Sound
26. Scripting API Reference | Project.Model.Sound
  • Sound.setFadeInCurve Sets the fade-in curve of the instrument to the specified length and curve shape.
  • Sound.setFadeOutCurve Sets the fade-out curve of the instrument to the specified length and curve shape.
model.CommandSound
An instrument that triggers an API command.
See Also: Command Instrument
model.EventSound
An instrument that references a model.Event or snapshot to play.
See Also: Event Instrument, Snapshot Instrument
model.MultiSound
A container instrument that selects from a playlist of other model.Sounds.
See Also: Multi Instrument
model.PluginSound
An instrument that uses an external DSP to generate sound.
See Also: Plug-in Reference
model.ProgrammerSound
An instrument that can be assigned an asset at runtime.
See Also: Programmer Instrument
model.SilenceSound
An instrument that plays nothing for a specified amount of time.
See Also: Silence Instrument
model.SingleSound
An instrument that plays a single audio asset.
See Also: Single Instrument
model.Sound
The base class for all instrument types.
Instruments can be placed on a track, or within a model.MultiSound playlist.
model.SoundScatterer
A container instrument that applies temporal and spatial randomization to a playlist of other instruments.
See Also: Scatterer Instrument
Sound.setFadeInCurve(
    length,
    curveShape
length
The numerical duration of the new fade-in curve.
curveShape
The numerical velocity of the curve. A value of 0 creates a linear fade-in, a positive value creates an accelerating fade-in, and a negative negative value creates a decelerating fade-in.
If no fade-in curve exists on the sound, one is created. If length is approaching zero, no curve is added. If the curve has an existing fade-in curve, it is removed. If no curveShape is provided, the default shape is used instead.
    length,
    curveShape
length
The numerical duration of the new fade-out curve.
curveShape
The numerical velocity of the curve. A value of 0 creates a linear fade-out, a positive value creates an accelerating fade-out, and a negative negative value creates a decelerating fade-out.
If no fade-out curve exists on the sound, one is created. If length is approaching zero, no curve is added. If the curve has an existing fade-out curve, it is removed. If no curveShape is provided, the default shape is used instead.
See Also: Instrument
