Scripting API Reference | Project.Model.Track
26. Scripting API Reference | Project.Model.Track
model.AudioTrack
The base class for tracks that can contain instruments.
See Also: model.Sound
model.GroupTrack
A track within an event that is associated with a mixer group.
See Also: model.Event, model.MixerGroup
model.MarkerTrack
A logic track containing logic markers.
AudioTrack.addAutomationTrack
Creates an automation track for a given property of an automatable object.
AudioTrack.addAutomationTrack(
    automatableObject,
    propertyName
automatableObject
Any model.AutomatableObject of the track such as a model.Sound, a model.MixerEffect, or the model.MixerBus of the track itself.
propertyName
Any valid automatable property of the specified model.AutomatableObject.
Returns the automation track ManagedObject.
Automation can be present even if the automation track is hidden.
// adds an automation track for a master track's volume
var event = studio.project.workspace.addEvent("New Event", true);
var masterTrack = event.masterTrack;
var automationTrack = masterTrack.addAutomationTrack(masterTrack.mixerGroup, "volume");
// adds an automation track for a gain effect's gain
var gainEffect = masterTrack.mixerGroup.effectChain.addEffect("GainEffect");
var automationTrack2 = masterTrack.addAutomationTrack(gainEffect, "gain");
See Also: Tracks
GroupTrack.addSound
Adds an instrument to the track on the model.Parameter specified.
GroupTrack.addSound(
    parameter,
    soundType,
    start,
    length
parameter
The parameter sheet to add the sound to.
soundType
The type of the model.Sound. Must be model.SingleSound, model.MultiSound, or model.ProgrammerSound.
start
The numerical position of the new model.Sound. The value must be within the parameter's range.
length
The numerical length of the new model.Sound.
Returns the model.Sound ManagedObject.
See Also: Tracks
GroupBus.getItem
Retrieves the mixer bus at the relative path specified.
GroupBus.getItem(
    path
path
Relative path of the entity to get the model.MixerBus of.
Returns the model.MixerBus at the relative path specified. Returns undefined if the bus cannot be found.
var bus = studio.project.workspace.mixer.masterBus.getItem("sfx/player");
MarkerTrack.addNamedMarker
Adds a destination marker to the marker track at the given position.
MarkerTrack.addNamedMarker(
    name,
    position
name
The string value to assign the marker when created.
position
The numerical position to place marker.
Returns the named marker ManagedObject.
MarkerTrack.addRegion
Adds a destination region to the marker track at the given position with the given length.
MarkerTrack.addRegion(
    position,
    length,
    name,
    loopMode
start
The numerical start position of the new region.
length
The numerical length of the new region.
name
The string value to assign the new region.
loopMode
A number representing the region's loop mode. Defaults to project.regionLoopMode.Looping if loopMode is undefined. The loop mode can be set by passing in a valid loopMode argument, as described by the Project.regionLoopMode enum.
Returns the newly created region's ManagedObject.
MarkerTrack.addSustainPoint
Adds a sustain point to the track at the given position.
MarkerTrack.addSustainPoint(
    position
position
The numerical position to place the new sustain point at.
Returns the SustainPoint ManagedObject.
MarkerTrack.addTransitionMarker
Adds a transition marker to the track at the given position.
MarkerTrack.addTransitionMarker(
    position,
    destination
position
The numerical position to place the new transition marker at.
destination
A ManagedObject of type NamedMarker or LoopRegion.
Returns the newly created TransitionMarker ManagedObject.
MarkerTrack.addTransitionRegion
Adds a transition region to the track at the given position with the given length.
MarkerTrack.addTransitionRegion(
    position,
    length,
    destination
position
The numerical position to place the new transition region at.
length
The numerical length of the new transition region.
destination
Either a NamedMarker or a LoopRegion.
Returns the TransitionRegion ManagedObject.
