Scripting API Reference | Project.Workspace
26. Scripting API Reference | Project.Workspace
The root workspace ManagedObject of the project.
Methods:
workspace.addEvent
Adds an event with the given name to the project.
workspace.addEvent(
    name,
    withSpatializer
name
The string value to assign the new event.
withSpatializer
A bool value determining whether to add an FMOD spatializer to the new event's master track.
Returns the event's ManagedObject.
The withSpatializer argument should be true if a spatializer on the master track is desired and false otherwise.
workspace.addGameParameter
Adds a parameter to the project.
workspace.addGameParameter(
    parameterDefinition
parameterDefinition
The object describing the parameter to add.
Returns the parameter ManagedObject.
The properties of the parameterDefinition object match those of the object given as an argument to the Event.addGameParameter function.
workspace.addTag
Adds a tag with the given name to the project.
workspace.addTag(
    name
name
name of tag to add.
Returns the tag ManagedObject.
If the tag already exists in the project, the existing tag is returned instead.
workspace.createPlugin
Creates either a plug-in effect or a plug-in instrument.
workspace.createPlugin(
    identfier
identifier
The plug-in to use for the creation. This must match the name of an FMOD_DSP_DESCRIPTION.
Returns the plug-in effect or plug-in instrument ManagedObject.
