Scripting API Reference | Project
26. Scripting API Reference | Project
The studio.project module provides access to objects within the project model.
Methods:
Callbacks:
Properties:
project.build
Builds all the banks to all the platforms listed in the build tab of the preferences dialog.
project.build();
project.build(
    build_options
build_options
Builds the project with options object { banks, platforms }.
Returns true if the operation succeeds, or false otherwise. Building individual banks also builds and updates your project's master banks and master bank strings files.
// Single banks
    studio.project.build({ banks: 'Weapons' }); // Build the "Weapons" bank to all platforms
    studio.project.build({ banks: 'Music', platforms: ['Desktop', 'PlayStation 4'] }); // Build the "Music" bank for only the "Desktop" and "PlayStation 4" platforms
// Multiple banks
    studio.project.build({ banks: ['Weapons', 'Characters'], platforms: 'Desktop' }); // Build the "Weapons" and "Characters" banks only for the "Desktop" platform
    studio.project.build({ banks: ['Weapons', 'Music'], platforms: ['Desktop', 'PlayStation 4'] }); // Build the "Weapons" and "Music" banks to the "Desktop" and "PlayStation 4" platforms
// Platforms
    studio.project.build({ platforms: 'Desktop' }); // Builds all banks for the "Desktop" platform
    studio.project.build({ platforms: ['Desktop', 'PlayStation 4'] }); // Builds all banks for the "Desktop" and "PlayStation 4" platforms
project.create
Returns a new instance of a ManagedObject of the given entity name.
project.create(
    entityName
entityName
The name of the entity to create.
This will create any required child objects for the object (e.g. creating an Event will create and attach its EventMixer).
project.deleteObject
Deletes the ManagedObject and its references, if any, from the project.
project.deleteObject(
    managedObject
managedObject
The managed object to delete.
This is the equivalent to deleting an item in the user interface.
project.exportGUIDs
Exports project "guids.txt".
project.exportGUIDs()
project.findAvailablePlugins
Returns an array of strings that lists all available plugins.
project.findAvailablePlugins()
project.importAudioFile
Imports an audio asset into the project.
project.importAudioFile(
    filePath
filePath
The absolute path to the file's location.
Returns an model.AudioFile, ManagedObject, or null if importing failed. The file is always imported into the root audio bin folder. Use the AudioFile.container relationship to reassign it to another folder.
project.lookup
Lookup a ManagedObject by path or GUID.
project.lookup(
    idOrPath
idOrPath
GUID or path of the ManageObject.
Returns a ManagedObject found by GUID or path.
var item = project.lookup("{3a731ab3-ce6d-453d-862e-32050cecf68a}");
var event = project.lookup("event:/path/to/eventname");
var eventFolder = project.lookup("event:/path/to/foldername");
var bank = project.lookup("bank:/path/to/bank");
var snapshot = project.lookup("snapshot:/snapshotname");
var vca = project.lookup("vca:/vcaname");
Paths are formatted using the pattern type:/path/to/item, where type is one of:
  • event
  • snapshot
  • bank
  • bus
  • vca
  • asset
  • parameter
  • effect
  • tag
  • profilersession
Paths can also be used to find container items, such as finding a folder in the event hierarchy.
project.save
Saves the project.
project.save()
project.audioFileImportedConnect
Sets a function to be called when an audio file is imported, with the signature function(audioFile).
The audioFile argument is a model.AudioFile object.
project.audioFileImportedConnect(
    callback
callback
A callback function that will be called when an audio file import has completed.
project.audioFileImportedDisconnect
Disconnects the connectFunction once it is no longer needed.
It is important to disconnect the connected signals when they are no longer needed, otherwise they can accumulate and cause unexpected behavior.
project.audioFileImportedDisconnect(
    connectFunction
connectionFunction
The callback to disconnect from audio file imported notification.
project.buildEndedConnect
Sets a function to be called after banks are built, with the signature function(success).
The success argument will be false if a build error occurs or the build is cancelled by the user, and true otherwise.
project.buildEndedConnect(
    callback
callback
A callback function that will be called when the build has ended.
function buildEnd() {
    alert("Build about to end");
studio.project.buildEndedConnect(buildEnd);
project.buildEndedDisconnect
project.buildEndedDisconnect(
    connectFunction
connectionFunction
The callback to disconnect from build ended notification.
studio.project.buildEndedDisconnect(buildEnd);
project.buildStartedConnect
Sets a function to be called before banks are built, with the signature function().
project.buildStartedConnect(
    callback
callback
A callback function that will be called when the build has started.
function buildStart() {
    alert("Build about to start");
studio.project.buildStartedConnect(buildStart);
project.buildStartedDisconnect
project.buildStartedDisconnect(
    connectFunction
connectionFunction
The callback to disconnect from build started notification.
studio.project.buildStartedDisconnect(buildStart);
project.filePath
The absolute path to the project's ".fspro` file on disk.
project.distanceRolloffType
An enum corresponding to different distance attenuation roll-off types available to spatial effects.
distanceRolloffType: {
    LinearSquared: 0,
    Linear: 1,
    Inverse: 2,
    InverseTapered: 3,
    Custom: 4,
project.parameterType
An enum corresponding to different model.Parameter types available.
parameterType: {
    Invalid: -1,
    User: 0,
    UserDiscrete: 1,
    UserEnumeration: 2,
    Distance: 3,
    Direction: 4,
    Elevation: 5,
    EventConeAngle: 6,
    EventOrientation: 7,
    Speed: 8,
    SpeedAbsolute: 9,
    DistanceNormalized: 10
project.regionLoopMode
An enum corresponding to different loop modes of a loop region.
regionLoopMode: {
    None: 0,
    Looping: 1,
    Magnet: 2
parameterDefinition
Describes a model.Parameter.
    type: [number],
    min: [number],
    max: [number],
    enumerationLabels: [array]
name
The name of the parameter.
type
The project.parameterType of the parameter.
min
The minimum value of the parameter range.
max
The maximum value of the parameter range.
enumerationLabels
A string array of labels to apply to each index of the parameter. (Type UserEnumeration only).
See Also: Event.addGameParamater, workspace.addGameParameter
