Unity Integration 2.03
This section describes the major features introduced in the 2.03 release. See the Detailed Revision History for information regarding each patch release.
General runtime features and improvements, including any API changes relevant to scripting, are documented in the API what's new page.
This release focused on improving general performance and fixing bugs with no significant changes to the FMOD for Unity plugin.
Removed support for end-of-life versions, minimum is now 2021.3.
This section describes the major changes that occurred in 2.02.xx leading up to the release of 2.03.
Added support for Unity 2022.2 and 2023.1.
Emitters are now able to be triggered from UI elements using mouse events.
Added non-Rigidbody velocity effect option on Emitters. If enabled, it allows for the Doppler Effect to be used without the need for a Rigidbody on the GameObject.
Added to the Settings is an option called Event Linkage, this determines how FMOD for Unity handles event paths changing due to events being renamed or moved in FMOD Studio.
Added support for Android x86_64 and Apple Vision Pro.
